MagnetoSound
The shunt goes across the meter (between + and - ). The series resistor (maybe there is one already if you have a trimmer) goes ahead of it. Or between - and ground if you prefer.
By adjusting the two values you should be able to set a zero point and a sensible deflection range.
I cannot offer values, sorry. They will depend on your meter more than anything, but the shunt will probably need to be close to the resistance of the meter coil.
