Category 5
I finally got a nice Extech True RMS Multimeter. I have been using the Radio Shack folding pocket meter to check voltages and resistance up until now.
Here's the deal.
On the little $25 pocket multimeter, when I connect the two leads together on the resistance setting it reads 00.0 ohms. This seems right to me since there is obviously no resistance other than the leads themselves. It is as if the meter is calibrated to read the resistance between the leads, minus the resistance of the leads themselves.
The new meter, regardless of the lead pair I use, readys 00.1 - 00.4 ohms fluctuating when no resistance is present. I often use the resistance setting to test the integrity of solder joints, and a reading of 00.3 would make me want to go back and resolder the connection.
Is it normal for a true RMS meter to read a small amount of resistance when none is present, or is my meter bad?
Shane
Here's the deal.
Shane
