hitchhiker said:My hope is to try in reverse this fairly large UTC 1 : 7.45 output from the RCA BA73 program amp. With a multi-tester the readings are just under 0.9 ohms and 31 ohms. I've ran music through these in 7.45:1
step down into a V72 and the result was quite OK. John, do you think they are likely to work well in this circuit?
It's an old one to respond to, but a BA-73 output is 600 ohms on the high side; far too low to reverse and stick on a tube plate impedance with any success.
