Stack-Chain here also....
A transformer with dual 16VAC and a 48VAC secondary winding for 500 series builds (not 51X) alone, NO. A transformer is transforming to AC voltage(s) at a specific ratio. Your 500 series builds want DC voltage(s). A Transformer is only one part of a PSU. If this transformer (comming with whatever current rating per secondary winding) 'will work okay', when followed by rectification, loading caps, regulation of at least the +48V part, ..., depends on your definition of 'a couple of'.kquick said:.. a couple of these .. for 500 series builds. Will a 16x16x48 power trafo work okay for a power supply?
kquick said:I know this is a noob question. Picked up a couple of these from your online store want to use them on my bench for 500 series builds. Will a 16x16x48 power trafo work okay for a power supply?
Kim
Igor said:kquick said:I know this is a noob question. Picked up a couple of these from your online store want to use them on my bench for 500 series builds. Will a 16x16x48 power trafo work okay for a power supply?
Kim
For 51X, NO. For 500 series, YES.
It is possible to apply the voltage right after diode rectifier/about 2200uf caps to +/-24V; 16V regulators are on-board.
Or, you can apply the voltage from your regulated +/-16V, +48V power supply to Rackit! and not install 16V regulators.
Harpo said:A transformer with dual 16VAC and a 48VAC secondary winding for 500 series builds (not 51X) alone, NO. A transformer is transforming to AC voltage(s) at a specific ratio. Your 500 series builds want DC voltage(s). A Transformer is only one part of a PSU. If this transformer (comming with whatever current rating per secondary winding) 'will work okay', when followed by rectification, loading caps, regulation of at least the +48V part, ..., depends on your definition of 'a couple of'.kquick said:.. a couple of these .. for 500 series builds. Will a 16x16x48 power trafo work okay for a power supply?
Anything. The pads marked +/-16, +48, agnd, case are already connected to 18-pin connector.When I leave out the 16V regulaters on rackit will I need to jumper any thing?
kquick said:... I am only building 500 series no 51X.
[silent:arts] said:kquick said:... I am only building 500 series no 51X.
Kim, you should rethink your plans
Igor said:[silent:arts] said:kquick said:... I am only building 500 series no 51X.
lol
Yes, IMO way better than running stuff requiring 24V on dc/dc converters.
However, there are many projects which require +/-16V only, so, let people make their choice.
If I use a +/- 24V, 48V PSU and leave the 16 Volt Regs in the rackit then I should be able to test 500/51X.
IS correct
johnnyscotch said:Sorry for the noob question, but say I wanted to use 2 of these to make a simple 1u case for a couple of normal 500series preamps.
Can anyone point to a reasonable PSU option? Like the JLM stuff? Anyone around sell a suitable torroid for this?
I'm just still a little confused as to if these boards do some kind of regulating, or you need a regulated PSU for them.........
cheers
Eric
Yes. ;D. (+/-24VAC doesn't make much sense as it will be different every next blink of an eye)sonic02 said:Do I need a regulated power supply? i.e +/-24DC, or do I need +/-24AC?
... a bipolar or dual rail (maybe tracking) bench PSU or two single rail PSUs. You want at least +24VDC and -24VDC with 0V reference voltage in between. Connecting mics that rely on phantom voltage, an additional 48VDC supply may be needed.Looking to buy a bench PS.
It won't. In case you don't have the +/-16V rail voltages from an external PSU (only needed for preamps/compressors/billboard-top-10-generators/whatever connecting to the API-500 standard 15-pin cardslot config), the Rackit -with regulators and voltage setting network resistors fitted- can regulate these maybe needed rail voltages down to +/-16VDC when fed from an external +/-24VDC PSU, connecting to the additional 51X supply rail pins (18-pin cardslot config).From my understanding the 'Rackit' will rectify and regulate the AC supply to DC.
sure does, and uses the API-500 format 15-pin cardslot. If you only want to power this card, there are enough fixed or variable +/-xVDC (value of x depending on DOA used) with +48VDC included PCBs or kits around this forum. A bench PSU with its only purpose to power this single preamp looks a little oversized. YMMV.sonic02 said:.. the VP26 looks tasty)
