RACK-IT! 500/51X -> to 19" rack and easy-to-test solution.
Where are front panels available? I have the partial kit from the online store but I need the front panel, thanks
So this would basically be a smart move if I had psu that runs at 24V (running two neves) and I want to run two additional 500 modules (ssl 9k) in the same box with the respective voltage, which then would be regulated down to 16V at igor's ps?
missing another 24V psu (and probably/maybe an additional +48V supply for phantom powered mics). Your 24V psu for your neves probably is a single rail psu. These 500/51x modules are powered by dual rails, IE +24V and -24V with a 0V reference voltage in between, that is 48V between these +/-rails, if it is a +/-24V supply. These rails can get regulated down to maybe +/-16V for the api500 format 15-pin cards by the RACK-IT.
hi guys,
I cant find the "18 PIN DUAL SIDE CONNECTOR PCB TERMINALS"on mouser.. If someone can help me, please ? Where to find this ?
So what have people who've built this as a test tool used as the PSU?
Unfortunately my bench PSU is not bi-polar so I was considering getting a 48V switching PSU, putting it in a little box and then deriving the + / - 24V from that.  Seems like the cheapest and quickest option.
I've built 1 as a test supply and am in the process of building another (a more glorious one that will also run eurocard modules...)
I used a +/-24V card from dantimax for the first one, coupled with a cheapo hammond transformer. It works well enough to check a module is working fine, but the buzz from the transformer is a bit annoying..
The second one I'm using the nice little PSU card from diypartssupply and a £20 toroidal transformer from farnell...
Is there somewhere a BOM and a guide for newbies? 😇
Here's a BOM for v1.4 of the µRack
4 J-04-SIP-100 /A, /B, A, B
5 JUMPERS
4 0.1 UF 50V X7R 2.5MM C2, C7, C10, C14
2 47X25V 33...100uf 25v low esr 2,5mm C5, C12
2 220X25V 150...330 uf low esr C3, C16
2 220X35V 150...330 uf low esr C1, C9
2 200R 1/4w 1% mf R1, R4
2 2K41 1/4w 1% mf R2, R3
4 1N4004 1N4004 D1, D2, D3, D4
1 317 LM317TS IC3
1 337 LM337TS IC4
2 18 PIN CONNECTOR MOD_1, MOD_2
2 NC3FAV CON-NEUTRIK_AG_NC3F IN1, IN2
2 NC3MAV CON-NEUTRIK_AG_NC3M OUT1, OUT2
1 NC5MAV NC5MAV PS
There is surprisingly little documentation on this project. Has anyone else built it? Or is planning to build?
If so, I think it's best to attach the voltage regulators to the back panel before soldering the pins to the main board to ensure they are flush and don't stress the regulator solder pads when you tighten the screws, like this...
There may be no remaining interest in this project, but perhaps someone will come along years from now with questions and find this helpful.
PS: the existing holes did not line up so I drilled new ones. I also pushed the header pins (through the plastic guides) as far above the PCB as possible. Otherwise the capacitors on this board will bump the capacitors on the main board. More forthcoming...
