RCA Ba2A Pre amp qestions & answers
Hi everyone, I'm getting my two BA-2 back on the workbench to check for some minor hum that is probably as loud as the preamp self noise. It might be caused by a non optimal placement of a 230V-110V step down transformer. But testing seems strange:
My issue is that I'm confused on how to test the hum properly. I tried it with a 150 ohm XLR plug, but it seems to behave differently than a mic. Also, line level fed from the interface makes the hum type change (not reacting to the transformer placement at all). It feels like there are too many variables and I can't come to any conclusions. Sometimes the hum changes with moving the step down transformer, with other constellations it doesn't.
What's the proper feed to test the noise of a BA-2?
If you connect a XLR plug with 150 ohm between p2 and p3, the input transformer should be dead silent (you could also try directly connecting p2 & p3 with a wire lead as a sanity check, this only changes the impedance the grid 'sees'). You don't want the 150 ohm going to XLR p1!
With that 150 ohm connected you should hear & measure only the preamp noise. It will behave differently than with a mic connected because the mic could have some noise/hum that is masking the preamp noise.
I also measure with RMAA and a sound card connection (the level sent to the preamp needs to be reduced from line level, down ~40 dB).
This is really helpful as you can see spikes for 60 Hz (typically magnetic coupling) and/or 120 Hz (power filtering or routing). Right now you are guessing it is placement (magnetic coupling) but you can get a better idea with this measurement.
I find it really helpful to start with a known good external power supply. I have a heathkit IP-17. I also have a beefy standalone DC 6.3V power supply.
I will hook these up with the 'in progress' power supply turned off and disconnected.
With the preamp working like this with good noise measurements, I move on to:
1) turn on the 'in progress' power supply. Without it connected electrically, this will show any magnetic coupling. 60 Hz noise? Try to re-orient transformers or shield the PT. Ideally for EI transformers, the cores should be at right angles and off-axis.
2) connect the 'in progress' power supply and compare. 120 Hz noise? Bad filtering, wire routing, ground layout.
Another thing to watch out for when you have the lid off and you're trying to evaluate the noise, is lights (especially on dimmer switches), monitors, or other stuff around the room that could be inducing noise in the preamp.
Fast way for testing mains transformer induced hum is taking them out and reconnect with extended wires, then measure as suggested by Dmp. BA-2's self noise should be very low because they used triode wired pentodes at relatively low current (no partition noise, rectifier ripple is easy to filter).
I don't have a professional grade external power supply like the Heathkit, but I'll receive another external step down transformer in the next days. I'll reconnect with that and use the XLR plug and see from there. I use REW for measurement.
Thanks for the detailed response!
Originals -
Noise can be very different depending on what's connected. Ground noise through the case with a line connection can be very different from mic connection. A preceding piece of equipment may require benign connected to the same power outlet, or may require a cable with shield lifted on the BA-2 side.
As stated, start with a 150Ω resistor across pins 2-3.
In some cases there's more hum with the primary center tap grounded, in others more without it grounded. That can seem nonsensical from one unit to another.
Does hum change with gain pot position? If not it's possibly a V2 that has developed filament noise. Try grounding V2 grid.
Try grounding V1 grid. If hum present make sure it does or doesn't change with gain pot. More clues.
Usually it's a matter of comparing all the various scenarios and picking the best for the most used.
Use of an external supply instead of the internal might tell you something useful, may be more confusing to eliminate the natural steady state.
External transformer could definitely contribute. Be sure ground follows through from wall to preamp case. The 1930's RCA gear with external power transformers specified having the transformers at least 3 get away from the amps.
Bottom line once all else eliminated/improved is whether or not hum/noise meets published spec.
Originals -
In all scenarios hum changed with gain pot. And it behaves identical in both the BA-2A and the BA-2C that I have. When working with line level, hum is usually 50 - 70 dB below signal. That's good to work with. For a low signal from a dynamic mic I find it acceptable, but not great.
From what you describe I feel like I shouldn't expect them to be totally hum free. I'll check everything that's been recommended here within the next days. Good thing is, I have two of them and they behave identical. Makes it easier to check what works and what not.
I would re-check which tube in V1 position gives lowest hum level, it can change as tubes age; usually not but sometimes.
I have never disconnected the filament winding center tap and replaced it with a hum pot; could be worth trying if all else fails.
Are these 'originals' (vintage RCA) or your own builds?
What does this mean? Sending line level into the input transformer or are you using a pad? What is the gain of the preamp? 40 dB gain?
You can definitely build a BA-2 that is hum free.
Sending line level through a 35db U pad to the input. I actually have two switchable input pads, a switchable output pad and each input and output transformer taps on a switch. V1 and V2 have been checked. No bad tubes.
Now that I know that testing with a 150 Ohm pin 2 to 3 XLR plug will do, I'll strip off all switches and pads, connect the 150 Ohm plug straight to the 250 Ohm tap on T1. Connecting a step down transformer at a distance and measuring noise at T2 250 Ohm output. That should be a clean start.
Will report on what I can find out. Thank you everyone for some good advice!
Ok, had a full day of testing today. Disclaimer: I had already racked both BA-2 with a breakout box on the back and used it that way for a year:
- XLR ins and outs, a three position switch for a) direct input to T1 - b) Mic in with 20dB pad - c) line in with 35dB pad
- above the XLR out: a 6dB pad
- toggle right: T1 input transformer 250 Ohm or 30 Ohm tap
- toggle left: T2 output transformer 250 Ohm or 600 Ohm
That's the functionality I wanted to keep if possible.
What I did: Placing the step down transformer out of the rack and checking the bad things that the box wiring might do.
Findings: Yep. Step down transformer needs some distance (no surprise, I guess). And, I replaced the cables each from T1 and T2 to the back with double shielded ones. The ones I had were shielded, already, but they reacted so sensitive to their position and the surroundings, I just tried better shielded cables and the effect was noticeable. All in all, I brought down the hum 14 dB.
Here are some files, all recordings at 250 Ohm input tap, 250 Ohm output tap, gain pot at max:
01 - BA-2C direct T1 and T2 connection - 150 Ohm: That's the reference. The 150 Ohm plug is directly connected to T1. The output directly to T2. No break out box.
02 - BA-2C with Rearbox wiring - 150 Ohm: That's the best I could do with shielding and cable positioning. As you see in the images, basic noise is the same, but hum increases with the rear box wiring from -97 dB to -94 dB. That's a price I can pay for the added functionality.
03 - BA-2C with Rearbox wiring - SM57: I didn't know how to set up a reference so that the numbers make sense to you. So I just spoke into a SM57 at the same settings.
I know, it's not a proper test without a reference input, but I couldn't figure out how to do it, so I went for the practical SM57 test. What do you think? Is that a normal noise behaviour? From listening I think it's pretty acceptable.
  • 01 - BA-2C direct T1 and T2 connection - 150 Ohm.wav
    776.2 KB
  • 02 - BA-2C with Rearbox wiring 150 Ohm.wav
    776.2 KB
  • 03 - BA-2C with Rearbox wiring - SM57.wav
    20.1 MB
    86.5 KB
    87.4 KB
    1.4 MB
    3.6 MB
