Ok I see what you are getting at,
The meter will register lots of points as at ground potential when in fact there are subtle differences as I indicated in my earlier post. Most DMM's don't register milli ohms and the subsequent voltage drops, but the amps amplify them up to nuisance levels. As Lassoharp says, the last thing you want is a loop, its a recipe for hum.
Here's an analogy, if a piece of guttering is dead level, water may collect in some parts because there is no incentive to move in any direction, when its full it will flow but when the currents are low it doesn't flow. By putting a slight fall from one end to the other there is always the incentive to move to the lower level, that is what a busbar or a star ground does because it is the lowest level possible.
One other point, if there is a decoupling cap for each stage, return the negative as close as possible to where the cathode resistor is grounded, this reduces the length of current carrying wire to a minimum and there is less chance of inducing a current into sensitive areas. Same goes for large dia. wiring, there is less of a voltage drop in heavy wires to be picked up and amplified (milli ohms again)
best
