from my experience the UTC quality goes like this:
black cans - excellent quality
dark gray cans - great quality
light gray cans - good quality
light blue cans - (right before they went out of business) - not so good quality
i bet they checked the continuity of the pri and sec windings but did not check for shorts between shield and sec windings,
i thought i might have welded the terminals together with the heat gun while loosening up the glass tape, but i did a test with the heat gun and could not melt solder on either the low or high settings, and we used the low setting for taking off the tape,
early transformers had great taping and great processing as far as potting compound,
later stuff had wads of yellow poly and glass tape and amounts of potting compound that varied from "a little dab will do ya" to a full can of black tar,
now the black cans did have lams that were lower in perm than the dark gray cans, so the dark gray stuff is probably the best as far as electrical performance and quality control,
now how the amplifier itself made it out of the factory, that is the real mystery,
going to sweep the good one and see what it does, should be good to 5 hz with that mu metal core,
