systemtruck
Which I still can’t find haha.I think (not sure) that has been replaced by the tech docs section.
Click on forums (top left).Which I still can’t find haha.
It will certainly sound different on the new path unless you match up the magnetics with either new or old parts. I’d look for orig parts over time until they show up; they do.I have a BC-3B I'm working on. I'd like to make it "stereo." Should I just duplicate the Program booster amp and get a new output transformer from Cinemag?
[I very much considered building this program amp, and maybe I’ll come back to it, but for now I’m focused on single ended program / pre amps] -- Which one(s)?.....I very much considered building this program amp, and maybe I’ll come back to it, but for now I’m focused on single ended program / pre amps.
The RCA BA-2 and UA 610 preamps, and the GATES SA-134 Program Amp.[I very much considered building this program amp, and maybe I’ll come back to it, but for now I’m focused on single ended program / pre amps] -- Which one(s)?.....
[The RCA BA-2 and UA 610 preamps, and the GATES SA-134 Program Amp] -- THANKS!!!.....The RCA BA-2 and UA 610 preamps, and the GATES SA-134 Program Amp.
I’ve skimmed through the whole 20 pages of listed tech docs and also done a search in this site and google. Any ideas where the 230B manual ended up?Back to the RCA Hi-Z mixing - the Altec 230B console manual is now in the tech docs for comparison of method.
OK, sorry, wasn't seeing the negative voltage value. That's only used for bias in the preamp stages, practically no load. The later consoles do away with the negative rail entirely, I've posted about that in one of these threads, all differences are shown. Most people aren't aware that version exists.My negative won't come down with the monitor amp now running which makes sense per the schematic. However if I run a Sim of the resistors that I can find in series and shunting to ground I get -240 instead of -190. So I'm not so sure why or if that matters?
[the GATES SA-134 Program Amp] -- FYI: I just came across this little ditty a short while ago here in the New Year that you may have an interest in knowing about.....The RCA BA-2 and UA 610 preamps, and the GATES SA-134 Program Amp.
Yes I had seen that too, but thanks.[the GATES SA-134 Program Amp] -- FYI: I just came across this little ditty a short while ago here in the New Year that you may have an interest in knowing about.....
Any of the Gates remote amps with built in PSU have an unavoidable hum level due to high gain and power transformer proximity. The Fearn will win that battle. Sound again is a matter of taste. Many people swear by 134's, I know guys with large commercial facilities who have a half dozen of them. The middle pictured unit, and others of that pre-1947 era all have pretty high hum level so good for loud sources, but not quiet ones. The unit replacing SA-134 is the M5530, and it's quieter by a long shot, but pentode small bottle tubes versus triode front end octal on the SA-134. Different responses in the iron. etc etc etc. Lots of variables that will come down to taste. The large transformer SA stuff (like early cast aluminum case SA-39 input transformer type) is the best IMO, but it's pretty rare to find compared to the remote amps. There's SA stuff with smaller plain aluminum can transformers that do not sound as good IMO, and you see more of that when you see it at all.
