LeRoyLimited
Member
Hello All - long, long time lurker, but a new member and first time poster. I have successfully built an La2a and recapped/reduced noise on some vintage gear with the help of everyone here, so thank you, especially EMRR. It is a testament to the forum that I have spent a decade reading posts and have never had to ask a question due to the volumes of information already covered. That being said, I am still an amateur, so here we are:
A few years ago an old RCA Photophone noise reduction amplifier walked into my life, and though I don't have a use for an NRA in my little project studio, I kept it because pieces of this vintage, rarity, and high quality manufacture don't come around very often. So, it got put on the shelf in the corner as a display piece.
I knew the schematic was in Tremaine's, but only after looking at it for the hundreth time did it pop into my head that I might be able to easily repurpose this into a mic-preamp if the transformer after the 6V6 cathode follower was suitable. I tested DCR on the secondary, came up at 79, so I knew I was in the ballpark. Spent the morning tracing wires to the Cannon multi-pin, labeled and disconnected the leads from the output/interstage transformer, hooked up power and XLRs, and finally brought her up slow on a variac: She worked, sounded good and was dead quiet.
So, my question is, can I run it like this? I'd prefer to not unhook the unused parts out of historic preservation and laziness. Is there any harm in leaving them all connected to power? Should I pull the NR rectifier and DC gain tubes? Any preventative maintenance in the power supply or audio path I should look into? Someone before me put a few electrolytics in underneath, so this is not 100% original, but all of the multi-cap cans on top look to be.
I am used to cheap Gates program amps, where, in my experience, pretty much everything needed to be redone to get the noise floor low enough for modern use. Having everything work right off the bat without 60 hz hum from the power supply on the same board is blowing my mind. I would also guess there are a hundred m5576's for every one of these, so I want to tread respectfully. Would love to hear the thoughts and opinions of everyone before I get crazy in the woodshop making a nice case for this with proper xlrs and power cable. (unless someone miraculously has a spare RCA rack mount, pull-out slider case that this would slip right into...)
