clintrubber
This one's about realtime mimicing analog hardware by a computer.
Obviously circuit-simulations are nice, but wouldn't it be cool to have realtime emulation ? We have of course plugins, but as far as I know all of these are modelling the behaviour, so are not 'circuit-in/signalprocessing-out'.
I'm at least not aware of stuff that does it like that.
Anyone knows of computer-packages with which you can for instance draw a circuit, plug in a guitar and play thru the circuit, tweaking the controls as you go ?
First thing like that that I've seen is Korg's CMT (Component Modeling Technology), already from a few years ago.
"Korg's CMT tries to replicate every part of the original, every transistor, resistor, etc. to virtually recreate the MS-20's circuitry and thus - its sound!"
Dunno if it's really working like they say it's working, but let's give them the benefit of the doubt.
I could imagine though that it'd require quite some processing power, so some corners would have to be cut.
This software does load a computer though, so it might be true indeed that it's doing as advertised (weird reasoning :wink: ).
Of course it'd make little sense to model straightforward circuits on component detail if the analog randomness/parasitics/noises aren't taken into account. There is an 'analog' control added to the software to insert some randomness to the VCO's & VCF's, so all analog behaviour from the components won't be taken along and then brought back in later by this control.
So back to topic, anyone knows of stuff that 'really' simulates ? I'm aware of programmable analog hardware but that's not the same - I'm curious to software that's based on circuit-entry and at least captures basic functionality in real time.
Bye,
Peter
BTW, more on that Korg bundle here:
http://www.vintagesynth.com/korg/legacy.shtml
For some weeks now I'm the owner of that Korg Legacy bundle, which
is in essence several software synths and an uberfunky controller (a 84% USB-connected replica of a Korg MS-20 monosynth).
I hadn't expected I'd ever spend money on anything synthlike, but that controller made me do it. I'm not fond of synth-based music (to say the least), but I couldn't help, the tech-side of things does interest me.
That controller doesn't pass anything audio, it's purely a controller, but the integration is so transparent that it makes you think the sound is coming from that box itself.
You can even use the extensive patching-field: plug away with real patchcords and the computer senses & reacts accordingly (and of course draws the cords onscreen). According to reviews of people comparing the real & emulated MS-20, even patching-abuse (making totally illogical connections) is emulated correctly, so I guess that might best be emulated by mimicing the actual circuit. Just guessing here though.
Bye,
Peter
