Cyril Jones
Active member
- Joined
- Dec 22, 2011
- Messages
- 36
This is the Helios amplifier referred to above, my version compressed to a half size board also containing the voltage follower used in the Helios modules to drive subsequent stage of the Helios modules.. The pre-set potentiometer sets the gain when used as a stand alone amplifier rather than the microphone stage. Useful when used as the second post EQ stage. It is stable.
Nothing is available yet. There is a long thread about the design here:Wow, I’d be very interested in that one Ian ! I have only downloaded your previous Redd EQ design files, is this new mastering version available ?
Many thanks,
Louis
I absolutely don’t have the skills to assemble a pair of these Redd Eq´s…
+1...Yet! Everyone starts from that same place. If it's something you want to do, it's absolutely possible to work up to a build like this. The usual advice is to get your soldering skills honed in by starting on low-cost, low-risk builds like cables and guitar pedals, then try a preamp kit or two, and work up from there to a PCB-only project like this.
Believe me, if I can do it then you certainly can!
Unfortunately I cannot access the old site to edit it to include a pointer to the new one.Fantastic ! I hadn’t seen your new website.
Hi Herbert,Hi Grandmaster Ian, for sure!
It is also a good thing to share the .fpd with everyone who needs it. It is simple to modify it with the free FP Designer Software. Change the initials, change the drillholes for the used rotary switches like Grayhill 71ADF or 71BDF....Lorlin or Elma..and go..its a durable UV Print on anodisised Alu. You can calculate less than 100 Bucks for this FP. Perfectly for Studio usage. Frank from Frontpanels.de or Schaeffer AG do a real great job.
