Must be a Devo fan... ("we are Devo").
Yes, evolved Devo :grin: , not the one working in a coal mine, going down down..... :grin:
I described that summing structure in an article I wrote back in 1980 or so on console design.... but I didn't know it had a cute name.
Any chance to peek into that article? Is it online somewhere?
You could also pick up 6-10 dB using a lossless pan circuit.
Is there such a thing as lossless pan in practical life? I saw a thread on panning, but ... I don't know... Panning in my console is somewhat part of summing resistor, and I need those anyway, so why not just leave it as is.
Not to be a broken record, but if this noise level is already well below your program noise floor, you're just throwing money on the ground. You could instead buy beer with that money and mail it to me at my PO box ...
:grin: Yes, I know. I have checked noise levels of other consoles, and my toy mixer doesn't seem so bad in this regard after all. I've seen Sondcraft 3200 having 84dB S/N ratio with 16 channels up. And elsewhere 92dB SNR is considered very good. So I have almost 90dB SNR. I may just do the xlr pad trick at inputs after all, with a bit less gain reduction, and thus mic stage will work at lower gain, and lower noise. Maybe just a bit, few dB. I need to think about it for a while.
I may also change channel opamps from 072 to 5532. Noise would probably be the same, hopefully not worse.... I will try on one channel and see.
But bus rewiring with 'bus pcb boards' I will do surely, if nothing else, just to gain 8 aux sends per stereo pair, and to avoid cables hanging inside console. I may do balanced and devolved, or just one of those, or maybe just quasi balanced, lets see, need to let it settle a bit.
And for final summing bus I'm not so much into experimenting with new opamps after all. I'd rather go for SSL4000 mix bus, with transistor pairs and ne5534 - I already purchased SSM2210 transistor pairs for this purpose, months ago. And on post fader output stage I will put some lundahl transformers, which I cannot seem to use anywhere - would be shame to have them, but not use them.
gnd
