[quote author="gnd"]
I see. Like you explained, mix bus would work cooler, at lower gain, meaning lower noise and distortion.
If you see schematics of my console, after master fader, there is another 3x gain. Would it make sense to make this additional 3x already at channel, with channel output post-pan gain buffer? Thus instead of gain 1.68x, it could have gain 5x. Thus sum amp would still combine with unity gain, but at higher voltage output.[/quote]
That would indeed optimize bus S/N for the specific case of 10 dB post bus gain, but that same 10dB would come out of per channel headroom, not a very good trade off. Perhaps of academic interest, I did the exact opposite strategy in a series of small SR mixers where I moved the 10dB per channel fader gain to after the sum amp. This was useful in the live SR mixing environment where by the end of the night you'd find yourself mixing hot on the channel faders without the luxury of backing up and resetting all your mix levels.
For recording the 10dB gain post sum bus is mostly there to make all the faders the same (you don't want to confuse mix engineers) :wink: . If you need any gain there you're not hitting the bus hard enough.
How about summing resistors values? If I do usual summing bus (not devolved), there will be 24 channels connected to bus. Using NE5532 for channel buffers, I could go for lower summing resistor value, like 1k? But what about current then? 24 channels at high voltage output (possibly 10V with NE5532 at 5x gain) will create substantial current for sum amp. If I feed 10V on 1k sum resistors, thats 10mA from each channel, together 250mA. I would have to go discrete then on sum amp? What is max practical source/sink current for existing NE5532? Any suggestion on this?
thnx
gnd
PS: Regarding panning resistors, now they are normal carbon type. Would it be better to use metal film type? Would it matter?[/quote]
There are small noise improvements available from using reduced resistor values but in the context of other noise sources in the audio chain these will be pretty minor. To better match the R to a bus combining amp like 5534 (decompensated to like 10db or so), you consider the summing resistors all in parallel so even a 20k resistors will parallel down to less than 1k, so I wouldn't worry about it. Note: your analysis of needing to match the combined current from every input ignores that your bus would long ago have clipped, so that's a non-issue.
If you are trying to stay in dual opamp package to simplify mod perhaps try to find some newer dual that is decompensated. While a 5532 won't hurt you much running at a noise gain of 25x, a decomp part would be better.
Regarding resistor type I have never heard a difference but have seen distortion due to voltage coefficient in some cheap resistors used at high voltage (like in a power amp feedback network). If you already need to replace the parts to make a value change, you might as well use metal films which seem to be well liked, as your labor is worth more the the few pennies for resistor types (and you can then brag that you used the finest metal film resistors.) :grin:
thnx
gnd
