mypantsrblue
Active member
- Joined
- Mar 26, 2021
- Messages
- 35
Hey all,
I purchased a while back two 1176LNs that were given to former universal audio employee. they are silverfaced, and they carry serials 1176-001 and 1176-002. They are the protoype units that were created when they decided to reissue them. They are dated Dec of 1998. I was able to get UA to verify them, but they would not give me any info but that.
They're in slight disrepair. I have never plugged them in.
I took them somewhere and was quoted a very high price to fix them mostly for labor because the parts weren't that bad..... however I honestly think I can get them going with a little help. I am not as good as some of you, but I have built old and new Hairball 1176s and GSSL.
I have attached photos of the units in their current condition. I have an idea of what I want to do to start off with, but can anyone tell me what THEY would do first if they had these infront of them?
My plan was to check the wiring of and replace the caps in the power supply section, and then turn it on and see if I am getting +30 and -10 at the points listed on the schematic I'm looking at. I am using UREI schematic rev E, as I was told this is the closest I am going to get to the actual schematic. the PCB is also labeled so I will reference that for all component values. I think this +30 / -10 is the same across all anyway.
From there, I obviously need to replace the missing FETs, and I think I will recap the entire unit. I also see one power transformer has a wire thats come unsoldered etc.
What else would you guys do to these? I'm pretty confident that with new FETs and caps these will probably just start working.....
I also do know I'm missing a transformer for one, but luckily I'm in LA so I plan on getting it from Studio Electronics.
Thoughts?
Thoughts?
