[quote author="Svart"]looks good! i would switch the BJTs to logic level MOSFETs(with body diode) myself because of the inductive nature of the relay coils, but at such low levels i wouldn't be too concerned about the BJTs. [/quote]
Could you suggest some part nos.? This stuff makes my mind boggle! :?
[quote author="Svart"]Is this done in surface mount? you can get dual logic MOSFETs in so-8 packages as well as the others too. [/quote]
I fear it's through hole. I had a brief experience of trying to troubleshoot SO boards and hated it!
[quote author="Svart"]does that 40106 latch to high or low when triggered or does it just follow the input pulse? [/quote]
It does the opposite of the input; so the input is tied hi and goes Lo when the switch contacts, so the o/p is lo and goes hi when the switch contacts. Teh switch is a momentary though so the states are..well...momentary :grin: Just a pulse for the 4027 really..
[quote author="Svart"]I started to think about it and you might be able to get away with rearranging the setup and using MOSFET driver ICs in place of the BJTs AND the 40106 parts since the 4027 has schmitt trigger-like inputs. the mosfet driver ICs come in various standard types of logic inputs and a high/low output that can drive high current (1+amps) which would be more than enough for the relays and LEDs and might reduce your parts count even further! [/quote]
That sounds VERY cool. Once again though I need a kick in the right direction!
:green:
[quote author="Svart"]the boss is sweating me right now so i'll think about it as i do some *real* work..[/quote]
Cheers so much mate! :thumb: :sam: :guinness: :green:
