SSLtech
Yes, my original wording was rather deliberate: "anyone who designed a great piece of gear completely by accident".
There's a big difference between an initial discovery and a finished design. :wink:
Many behaviours and properties are stumbled upon, but harnessing the property is part of the design.
I always maintained that the aphex has its place. I've been able to use it to integrate low-bandwidth source material into full-range, well-recorded program material. A treble boost won't help the two to match if there's no HF in the source; an equaliser just multiplies what's there, but it doesn't matter how much you multiply zero by, you still get zero. If you're struggling to dig up a bit of HF buried in the weeds, you're going to bring up a lot of noise along with it. The Aphex was handy for re-manufacturing HF harmonics from the high-midrange region, assuming that wasn;t buried in noise also... if it was, you had unsalvageable source.
The Aphex aural exciter was handy for solving this sort of problem: making brightness where there really wasn't any. A great solution, but if you dodn't have that problem, it was useless to you. I used to hate in the 1980's when producers would use it on already-too-bright brass!
Keiith
Keiith
