Jon Fields
New member
- Joined
- Apr 7, 2024
- Messages
- 3
I have a Mojotone Princeton Reverb where the reverb tank is picking up 60 Hz from the power transformer (not too obnoxious at reasonable reverb settings). Moving the tank out of the chassis eliminates the hum. Experimenting with placing the tank nearer the power transformer seems to indicate the open and closed side of the tank towards the amp chassis generate similar hum. Experimenting with various steel objects from my kitchen as shields does not seem to help. I know steel is not a top of the line mu-metal, but the tank chassis is also steel. Mu-metal is more expensive than reverb tanks!
I am considering buying a second reverb tank and scavenging it for the receive side pickup. Then I could consider mounting it in the same orientation near the main reverb tank's receiver. I would then wire it out of phase. If this was such a good idea, I wonder why no one makes one...
Thoughts?
Jon
Thoughts?
Jon
