So, anecdotical evidence?
Please, show us the maths. Some of us are pretty good at it.The evidence come from comparisons and experiments: "the math first and the ears next".
"For a 20-18.000 Hz capable motor you need a 1 - 1.5 microns aluminium..."
Dont get me wrong, you can indeed esperiment with a 6 micron thick alu foil (is a good choice if you are in trouble with a nightmare- difficult-to-handle 0.6 micron one, say you are at your first attempt in this field...), but is not fair to sell the idea of a perfect fine, workable 20-20000Hz ribbon mike built by a newby with such a material.Sorry about the harshness,
it's just that a post like
..is quite close to actual misinformation, unless you can back it up with solids. The interwebs are full of such half-a**ed claims about all things audio hardware, the intention of which is most often to discourage experimentation, to smokescreen real information and thereby to corner a market
which is almost the opposite of what we want here
btw BBC has that great monograph on ribbon mics, iirc nowhere calling for 1u ribbons
/Jakob E.
Speaking about BBC, the 0.6 micron foil I use is the very same Coles uses in their 4038 model (built on a BBC specific...).Dont get me wrong, you can indeed esperiment with a 6 micron thick alu foil (is a good choice if you are in trouble with a nightmare- difficult-to-handle 0.6 micron one, say you are at you first attempt in this field...), but is not fair to sell the idea of a perfect fine, workable 20-20000Hz ribbon mike built by a newby with such a material.
I've read my share of articles on ribbon mics, but I have never seen any mathematical relationship between ribbon thickness and HF response.Exactly, about what part of a 1924 ,well developed and evoluted invention (on which is possible to find tons of patents, studies, documents, diagrams, schematics, etc.) do you lack maths?
Obviously front-to-back distance is the main parameter in top end limit... but then came the inertia of the ribbon: double the thickness and you double the mass, hence the inertia, hence the top end rollout point moves... you can theoretically have your top end, but you'll never reach it. That's an experimental fact.I've read my share of articles on ribbon mics, but I have never seen any mathematical relationship between ribbon thickness and HF response.
There are claims that thinner ribbons have potentially better transient response, but not math.
OTOH, the relationship between front-to-back distance and HF response is well documented.
2,5×10elev−5 inches is indeed 0,63 microns... This is math. And this is BBC.The frequency response is a function of the front to back path distance. BBC Engineering Training Manual-Microphones (Robertson) PDF page 125 Here is a link to the BBC Monograph as well.
You are right, they do not call for a 1 micron ribbon, they call for 0,6...btw BBC has that great monograph on ribbon mics, iirc nowhere calling for 1u ribbons
/Jakob E.
