AnalogPackrat
[quote author="SSLtech"]Actually when you look at it that way, you're still tricking yourself somewhat.[/quote]
Hey, he's getting the efficiency he's getting. There is no trick. Show me a non-hybrid car of similar size to a Prius or Civic Hybrid (2500-300 lbs, 4+ passengers) that will do as well AND (this is also critical) with the extremely low emissions that these cars produce.
That depends on the speed, the gearing, and all the other design factors involved. Hybrids with CVT transmissions can better optimize efficiency by operating the engine at its optimal rpm over a wide range of speeds.
Maybe that's true in FL (and other flat states), but in general it is not for the reason you gave above. Cruise control is a stupid control loop that tries to keep speed constant. It undershoots and overshoots on hills due to control lag (no look-ahead is one way to look at it).
That costs you efficiency--you hit the base of a hill at 2500 rpm and the car slows down. Cruise control compensates by increasing rpm to accelerate the car on the uphill. Bad. Human sees hill and accelerates slightly ahead (on the flat) and slows slightly as the hill is climbed (so-called "driving with load"). As the the hill is crested a human will (with proper training) slowly let off the accelerator while cruise will overshoot the target speed and let off later.
Also, if the hill is steep enough, a hybrid can use some if its stored energy on the climb and recover excess potential energy on the downhill. No, this conversion is not 100%, but it's also not 0% like in a conventional car where you burn gas to accelerate and then waste all of the excess energy heating up your brakes.
I don't understand this mentality at all. it's one thing to point out factual errors in someone's analysis, but you haven't done that, IMO.
That's like saying "when reproducing a constant amplitude 1kHz sinusoid an 660 (or LA-2a) is just an expensive compressor." You missed the point. Well-designed hybrid cars (Prius, Civic, Camry, the late Insight) are a lot more than that. They are systems designed for efficiency, not just gas cars with electric motors bolted on (like some of the GM offerings).
These cars have aerodynamic designs (undercarriage as well), low rolling resistance tires, efficient engines, efficient transmissions, regenerative braking, much more computer control than the average car, etc. They are more than the sum of their parts--just like any other well-engineered product.
For example, the Prius engine is an Atkinson Cycle design. It produces only about 70hp from its 1.5L displacement, but it does it with high efficiency and low emissions. The Civic hybrid uses a modified VTEC variable valve system to operate the engine in three modes (power, pseudo-Atkinson, all valves closed) depending on the current operating conditions and operator input. It produces a maximum of 95hp from 1.3L, but when in pseudo-Atkinson mode has lower output and much higher efficiency.
A P
ANY gasoline vehicle will give best/lowest delta fuel consumption at highway speeds, and you can IMPROVE the Prius' cruise performance by throttling back slightly uphill... the computer doesn't "see" hills, but you can.
Cruise control usually beats human brain/foot/throttle interaction in gasoline vehicles, because the human brain EXPECTS to go faster downhill, and there is always a slight 'lead foot' instinct... even Granny has it.
The Prius is a good car, and I'm actually for hybrids, though I know my post history contains a good deal of counter-information, because I do feel the need to play devil's advocate.
At highway speeds the Prius is just a small gasoline car, with a slightly optimistic computer. it's biggest benefit is a fairly slippery shape and that it punches a rather SMALL hole through the air. -Other than that, it is subject to the same influences as conventional powertrain vehicles.
A P
