The zener noise should be pretty well filtered out by the 100r and 220uF. In addition, it is shared equally on both legs of the output, so any mic preamp with decent CMRR should attenuate it significantly.
The cold leg is referenced to ground, so there is no noise, except for the Brownian noise of the 50r resistor. The hot leg is referenced with an identical 50r to the discretete opamp, which has a sub-1 ohm impedance. The onluy possible explanation is that the opamp is noisy.
But, you say that with the opamp disconnected, noise is still there...
OK, what is the actual noise level?
