Well, I got the Telefunken tube today. It took 5 days to get here from Berlin, much quicker than I expected.
The tube is brand new, the printing is perfect, and the box was exactly as the picture the dealer sent me. It was $85 plus $15 for air mail shipping (US, paypal). The tube is marked both on the box and the tube itself as a 6922, made in June of 1968. Most Tele tubes of this type are marked E88CC, but the dealer explained that since it was a military stock tube it was listed as 6922 in order that foreign equipment using "6922" labeled tubes could be fitted with the same part number without confusion. the e88cc and 6922 are identical in every way (he even e-mailed me pictures if them side by side). Nevertheless I requested the 6922 just to be sure. He matched me a tube for like triodes, even though the NTK only makes use of one.
So how does it sound? Well, I did some quick dry vocals trhough the API before the swap and after. Both times I let the mic warm up for exactly one hour. I did not touch the preamp except for the initial level set.
1. The stock tube sounded good (I always liked the NTK) except for a little bit of a fuzzy sound on loud passages. I always noticed this since the mic was new, but just attributed it to the fact that the NTK is a tube mic. I also noticed (based on the comparison) that the stock tube has a little less low end, almost making it seem like there is a stronger upper midrange (around 1k'ish to 1.5k).
2. After changing the tube to the Tele I notice that the fuzzy distortion is pretty much gone. I guess it was an artifact of the Sovtek tube. Like guitar tubes there are probably grittier and cleaner tubes, and the Sovtek is definitely grittier than the Tele. You may find the grit desirable. The Telefunken tube also gives the mic some sort of upper frequency range harmonic that was not very present with the Sovtek. It is reminiscent of the character that I love in the ISA110, Neve 1081, Millennia HV-2, and Aphex 1100. I can only imagine it is the even order harmonics that I always read about. Whatever, overall the Tele is more smooth and has a more pleasant saturation. I also noticed that the low end was a bit more pronounced too, much like what I heard on the Mic Pre CD with the Manley mic. For what it's worth, the low end is on the verge of being "too" fat and warm, but I thought the Mic Pre CD had the same effect to an even greater degree (this was one of my initial gripes with the pre CD) so I have a feelling I am in the minority on thinking of this as a negative. After backing a little further off the mic the problem was solved, so I chalk it up to increased proximity effect. After a few listens, I am certain that the Telefunken is the preferable tube. The difference is noticable, and the loss of fuzz and addition of the extra smooth high end saturation makes the NTK a much nicer mic.
If anyone is interested I can make some MP3s of the samples and load them on my FTP. If not, I won't, so speak up.
For $100.00 I would say the upgrade is a no-brainer. It is evident that the "hand picked" tube that comes in the NTK as stock is just that..."hand picked" out of a box full of tubes. I imagine the Siemens, Mullard, and even Phillips JAN Military tubes will offer some improvement. The more I listen to the comparison the more I dislike the Sovtek. It sounds like there is a distortion pedal on the mic (very slight, but once you hear it it starts to really stand out).
I did not test the mic through any other preamps, so the low boost may be a combination of the mic and the preamp... I did not drive the preamp very close to peaking because I wanted to be sure I wasn;t hearing any clipping on behalf of the inout chain. I will try through the 1272, Millennia and MP20 next to see which I like the best. The API is my favorite pre right now so I went straight for it.
So has anyone got the schematics? Seems pointless to start replacing caps before we know how the circuit will benefit. After the tube change I am having fun with a "new" mic already.
Shane
