Well - so far.
Chopped input tx centre-tap, added phantom power and 20db pad. With cheap condenser pencil mic - tons of gain, but pad really screws up freq response. SM57 working but again bad roll off when pad engaged. Also phantom power (i know - it,s dynamic - but should be ok on balanced mic!) makes crackling sound when using dynamic.
Thought the pad/freq rolloff might be due to long input cable capacitance etc. Went direct from front panel xlr to transformer input - only 5cm twisted pair - no difference!! Changed pad values/impedance - but little if no improvement!
Ok - tried an oep 1:6.45 on input - wow WOW
WOW! - freq response now good with or without pad. No phantom power prob with sm57 - still loads of gain!!!
Tried direct out unbal via 10k pot - nice and also switchable to a carnhill 9600:600 out tranny - even nicer!
Put about 15-20mA extra load on B+ supply - brought it down from 340V to 315V.
Tried a pentode/triode mode switch on input stage - loud pop when changing - any way of curing this? Tonal quality does change and slight gain reduction in triode mode.
Gone from output of first stage and bypassed the pentode mixer and cap coupled into output stage. Works good so far - want me mate to take and test on numerous sources - my ears aren,t up to it!!
So nearly got all i want - struggling a bit with di input because of the feedback config utilising the transformer secondary. Ideally would like to toggle switch between mic/di and probably cap couple di for safety?!?
Would also like to add hpf similar to g9 between stages. Because of the hi impedance of the pentode stage - should i look at using the 470k pot that is already in circuit and scaling the capacitors by a factor of 10 smaller ie 10n change to 1n and 22n change to 2n2.
Any pointers from the gurus much appreciated.
