Siegfried Meier
Calibrate the EQ - I've noticed every trimpot comes standard turned up too high, so you need to perform this. And read this entire thread, because we've already discussed this.
Sig
Sig
stitch-o said:oops. yes, you are correct about connecting the PCB shields.
Fixed that.
What sort of heatsinks would fit on that configuration?
and, yes, the LOW signal/distortion is on both channels.
I'll try and take some better pics in a bit.
+ I know what you are looking for on the PCB as far as shorts, I'm going over it again myself right now...
Could I have put a wrong value part in somewhere possibly?
Cheers and thanks Matt!
stitch-o said:Is it normal to run across 'bad' resistors?
I powered down and disconnected my S800 and measured resistor values across both boards, here are the ones that stuck out at me:::
place board value channel 1 channel 2
r45 10k 6.92k 6.94k
r8 1.2k 1.163k 1.166k
r9 1.2k 1.163k 1.162k
r13 1.5k 1.437k 1.437k
r24 2.7k 2.28k 2.29k
r25 4.5k 3.47k 3.46k
r44 1.5k 1.371k 1.37k
r20 2.7k 2.29k 2.28k
r21 4.7k 3.47k 3.46k
r28 47k 10.2k 10.2k
r30 47k 15.5k 23.3k
r31 47k 15.5k 23.3k
r15 1.2k 1.154k 1.153k
r45 10k 6.94k 6.91k
r46 47k 10.5k 10.4k
r17 10k 6.92k 6.95k
r12 1.2k 1.152k 1.152k
r10 1.2k 1.153k 1.152k
r11 4.7k 4.06k 4.07k
anyone have any suggestions?
Cheers again!!
matta said:stitch-o said:Is it normal to run across 'bad' resistors?
r45 10k 6.92k 6.94k
r28 47k 10.2k 10.2k
r30 47k 15.5k 23.3k
r31 47k 15.5k 23.3k
r45 10k 6.94k 6.91k
r46 47k 10.5k 10.4k
r17 10k 6.92k 6.95k
Cheers again!!
Stitch,
You CANNOT measure across a resistor in circuit, power or no power... in order to measure correctly you would need to lift the leg of one end of the resistor.
I highly doubt that the kits from Colin would differ, I have built over 16 channels with the parts form Colin and have not had single issue.
I'm pretty sure that there is prob a placement issue we need to resolve, hence my suggestion for a BIG ASS pic of the board to look over for ya ;D
Matt
substitute said:I noticed R25 is marked 4k5 on the PCB, I'm using Colin's kits which came with no such value. But it seems like I have an extra, 4k7 will this work out?
