mata_haze said:Quick one:
I have lined my S800 up using a Neutrik A1 (fully balanced +4dB in -> +4dB out) but when it comes to use it on an insert point I loose roughly 6dB .
how do you usually wire your insert cables?
After I had a look at the S800 schematic I wired mine by shorting Pin 3 to ground (PIN 2 is hot for me of course) AT THE INPUT ONLY and left the output "floating" (PIN 3 disconnected).
Yet I have this 6db drop in level, just level no lost of low end or anything like that.
any thoughts?
Mattia.
peterc said:If you short one of the inputs to gnd you will lose 6dB of gain
Peter
no the console I am using does not have balanced insert points.matta said:Does your console have BALANCED insert points? MANY/MOST don't, and run unbalanced, so you are going to get a level drop from the console side into the EQ.
I have indeed wired the male XLR on the insert cable (SEND and therefore input of the EQ) shorting PIN 3 to ground (cold side), if I did otherwise (leaving PIN 3 floating)the level would be much less.Peter said:If you short one of the inputs to gnd you will lose 6dB of gain
Peter said:Mattia
Try wiring the return XLR like this:
XLR pin2 to hot on insert return
XLR pin 3 to cold on insert return
XLR pin 1 not connected.
It might give some level back.
REgards
Peter
Engfelt2000 said:I'm in the middle of building the box with 8 and I'm getting +12db louder from the output? Other than that it behaves normal. This occures so far on the four that I've finished so far. I doublechecked the output 47k resistors. I'm using the AML kit, which by the way is super. Any idea anyone?
Christian
matta said:Engfelt2000 said:I'm in the middle of building the box with 8 and I'm getting +12db louder from the output? Other than that it behaves normal. This occures so far on the four that I've finished so far. I doublechecked the output 47k resistors. I'm using the AML kit, which by the way is super. Any idea anyone?
Christian
Christian,
Had to set the onboard gain trimmer to reflect unity gain? I'm almost 100% sure from your description therein lies your problem. By default those trimmers are set higher, reflecting a much hotter output... read back a few pages and I discuss how to set the trimmer.
Matt
