A few questions for someone who understands this circuit? I don't have these mics, but I'm curious.
Skipwave's comment made me wonder about the through-hole (C5 and C6,unstuffed.. not sure they are really through-hole?) vs smd caps, stuffed. Seems if you stuff one or the other, you change which BJT transistor the source and drain of the FET go to. For example, if you follow 1 of the 2 traces coming off the FET (bottom of PCB, the left-most solder-pad), it connects to both the vertical (in the topside pic) SMD cap and C5. So if you stuff one, the signal continues to Q2, if you stuff the other, it goes to Q3... why?
Also, the schoeps circuit has the 150K resistors bypassed with a 470p cap. Any reason to do this here?
What about the other part of the circuit left out? Is it to bias the capsule? Doubt one could fit it in there unless you totally redid the PCB, but I still wonder why it's not there. Not like it's got expensive parts or anything, just one more transistor.
FWIW, here is the schemo (I think this is zebra50's site):
http://www.xaudia.com/xaudia/Schematics/Pages/Schoeps_Sony_files/Media/Schoeps/Schoeps.jpg?disposition=download
