ruckus328
a2d said:Well I just finished calibrating and doing a shoot out against the real deal, and I must say its pretty close to the real thing. a little darker, but very well done.
Haha, thanks!
a2d said:I only found one issue, The Gain reduction meter doesn't react as is should, I'll have to look into that or maybe thats the way it is.
Depends on the meter - $30 meter isn't going to react as your $100 sifam. And even those aren't completely linear at higher throws.
Definately no. The 12V regulator is running hot as it is, each of those bargraphs pull about 100mA, I wouldn't feel safe adding 1 more, let alone 3 with the existing supply. 3 would fry the regulator without the addition of a massive heatsink - you'd be burning like 7Watts.a2d said:One thought- do you think the power supply would be able to handle adding 3 more bar graphs, I'm thinking like the UA 2192
