SKJGProject
ok, but i really have 4 left so maybe somebody is missing some or you put more in than needed (like the 56r resistors) ;D
SKJGProject said:ok, but i really have 4 left so maybe somebody is missing some or you put more in than needed (like the 56r resistors) ;D
Winetree said:Disassembled the unit only to find my Hakko Desoldering Gun
can't desolder the 1meg switch pins without burning the sides of the two side switches. Tight fit.
Looking at cutting the center pin from the board and doing a jumper to the side pin.
Has Anybody done this.
canidoit said:Ruckus, I have not soldered my pot in. Please be a little patient here, it's not our fault that we have to do a mod on your board and it makes it difficult since you are not even supplying the schematics to do our own improvised mod of your mod.ruckus328 said:Winetree said:Disassembled the unit only to find my Hakko Desoldering Gun
No, I'll threepeat myself - you can't do it by cutting the trace, you have to physically remove the center pin of the pot from the board to severe the connection, there's no way around this, no if ands or buts, believe me if there was I would tell you. Pins 1 and 2 are connected in copper, bottom side of board, underneath the shadow of the pot, so pot has to be removed. Doing what you described would put you right back to square one.
As mentioned, use solder wick to remove it.
Anyways, if anyone has done Ruckus pot mod, can you please post a pic up of the pot installed on the PCB board![]()
emrr said:if he cuts his center pot leg free without desoldering, and puts a jumper wire from the pot center to the outer leg, it should get him there.
From what I recall reading it from somewhere I think, it is how the filter affects the compression. So for slope, the EQ frequencies are in a slope angle that affect the compression unlike the other settings which is a specific frequency dependent. I'm not sure how Boost works though?mulletchuck said:Ruckus, could you explain what A1, A2, Boost and Slope do?
ruckus328 said:Ensure TL074's are not in backlwards ("U" indent on the IC body represents Pin 1 side).
