Hindsight, probably should have gone with that lol. Single stage, pretty straight forward.The above is the original 82E01 used in the first 4K-series.
I had a big boo boo there. That section was overhauled in the schematic i just posted. Thanks for the heads up. When i was trying to lay out the board i was wondering why the net was telling me to dump the DI to ground... in the words of Homer J. Simpson... "DOH!".Need to look at the DI circuit
Also, pin 1 of both XLR's go to chassis ground, not to audio ground.
I think you should swap the values of R8 and R11, and increase R3 to about 100k.I think I've ironed out the problems with the schematic. In trying to lay out the board i found a bunch of silly errors.
Yes it is backwards. You have it as a 10;1 step down ATM. Mirror it.@abbey road d enfer appreciate the input, ill get on that. Also, i keep having this feeling that the transformer is backwards.
Correct.Should i be using it 1:10 no? I think i currently have it as 10:1...
Sorry, typo, I meant R30.should i up all the resistors going to the LED's to 100k or is it just that one in particular for some reason?
Ahhh that makes more sense! Thank you!Yes it is backwards. You have it as a 10;1 step down ATM. Mirror it.
Correct.
i have a nice signal going in
Ive sent in mic level pre transformer, i've sent it in post transformer as well, just seems that that first gain stage is running away and maxed out no matter what.What amplitude? The minimum gain is pretty high ( for line level input, fine for mic level).
The SSL "Class A arrangement" works with about 1.5mA (typically a 10k resistor tied to one of the rails), so the opamp thinks it's in class A for signals up to nominal operating level. Above operating level, cross-over distortion is masked by the signal. Here the current is about 100 times smaller, so the class A behaviour would be restricted to levels below about -40dBu.I was under the impression R73 from the original SSL schematic was to bias the opamp to class A.
Biasing Op-Amps into Class A
Far as i can tell it looks right. Im wondering if i should just bite the bullet and proto some boards. I never get breadboarding right with something complex. Guitar pedals, yeah, this… not so much.You said it was breadboard, that sounds like the feedback connection is not made correctly, so the op-amp is running open loop.
Nothing wrong with this. Not that it really matters. Was pertinent 40 years ago, now with modern electrolytics, not so much.R20 = 100k
Is that really correct?
