OddHarmonic
So I brought my first two Green Pre channels into work to set the CMRR, LEDs etc... I don't have a scope yet at home, but we have a variety at work.
Tektronics TDS 2014 4-channel digital scope
Tektronics 5110 scope w/ 5A14N 4-channel amp, 5B10N Time/Base Amp
Goldstar OS-9020A
As we usually use the digital scope and inject instrumentation signals directly, I have only found one pair of probes in the equipment closet:
Tek P6109 (10X, 1.5M, 11.8pF)
I read about setting the compensation for the probes by pulling the 5V Square wave from the scope and adjusting for a flat leading edge response.
Now, setting CMRR on the Green Pre requires that you observe the adjust to get the signal down to 1-2 mV. On all three scopes with these probes, there seems to be a noise floor of about 20-30 mV, preventing me from setting the CMRR below. I used my DMM (AC V) to adjust to 2 mV, but the scopes seem useless. I know that ain't right!?
The probes are certainly questionable, as they are probably pretty old and haven't been used in years. The two analog scopes suffer from the same question. The digital scope, however, is pretty new, and used often.
Am I using the tools incorrectly, or might the probes be bad?
thanks,
andrew
Goldstar OS-9020A
thanks,
andrew
