in the good microphone it is about 27vD2 gives 17,20v
D2 + D1 give 25,85v
D2 + D1 give 25,85v
If Uphantom=48vin the good microphone it is about 27v
Oui MonsieurSo I leave R13 & R14 as they are (27KΩ) and I put in serie between the 2 diodes a red led anode > cathode
if you don't get +/- 57v,So I leave R13 & R14 as they are (27KΩ) and I put in serie between the 2 diodes a red led anode > cathode
Do you remember how many discussions there were about the difference in Phantom voltage from 48v to 44v.Fine.
1) I'm gonna feed the 48v from my Presonus to verify the voltages (at my desk = Edirol USB powered)
2) got find a 3mm red led (got one or two somewhere... but where ??)
3) will install it as you said
R13= 0 ohm or 27k ?Here are the values with 48v Presonus :
Pin 2 = 38,79v / Pin 3 = 38,87v / D2 = 17,20v / D2+D1 = 28,24v / R18 = +56,02v / R19 = -56,04v / before R5 = 32,81v / after R5 = 20,55v / Fet D = 15,85v / Fet S = 0,36v / SA1015 e = 2,82v / K105 D = 28,10v / K105 S = 8,17v
(no led in serie with the zeners / no R in // with R13)
27KΩ original valueR13= ?
you have to put LEDs in seriesHere are the values with 48v Presonus :
I found a red led 3mmyou have to put LEDs in series
if you can't find it, put it in the same way, but 2..3 1n4148 diodes in series with the 2 zenner, checks, and measure again
Respect the polarity
0,08v... not enough ?R2 and R3 must be matched better
Upin2xlr = Upin3xlr
No0,08v... not enough ?
