yes That's the reason why I called the original Orig-mod (only because of the transformer Monacor and except that everything is original in it)Did you not put Monacor in both microphones?
Orig-Modmaybe, but I'm not going to operate on the Orig-mod
Both have Monacor (and R10 taken of)Orig-Mod
does it have a Monacor transformer?
Let's name them
Orig. and Mod
I think they are! (on the last pict I posted)If you do jFET BIAS on Edirol, when using Presonus, you will have more headroom until distortion
Make the sine wave symmetrical!
Do I use Edirol or Presonus ?If you do jFET BIAS on Edirol, when using Presonus, you will have more headroom until distortion
for audio tests you will use Presonus.Do I use Edirol or Presonus ?
set VR to 10k and analyze how the values varyOk for Edirol...
So I replace the 1,8KΩ installed by a VR10KΩ pre-settled at... 2KΩ ? and I bias more or less depend on the scope, right ?
Do I connect my 10nF (from smartphone) after the 1nF, direct on Jfet gate ?
It's correct because onI expected the Rsource value to be 3.9...5.6k, but for the K170 it seems to be lower.
I am used to the 2N3819, new from Central Semiconductor
