SE Electronics Z3300a
adjust R5//VR and R13//VR to get voltages as close as possible
in all important points
But has polarized U decreased in Mod mic?
R5//VR > VR seems to be full CCW and so is R13//VR
Polar 61,10v / after R5 21v
edit : RV // R5 reads 4KΩ (so RV must be at 28KΩ)
Following tests where I realized that I had to increase the R put in series with the one in // I ended up removing all the // and returning to the base values.
(RV100KΩ + 300KΩ) = 400KΩ in // with R13 and I would have to increase the value to lower the polar.
Same for R5 (RV50KΩ+33KΩ) = 83KΩ in // with R5 that was not enough.
Confirm that if I have to level up a full CW R in // with R1 that means that R1 si too small, correct ?
So the deal was not to lower the R but level them up ? because of the 9.1v zener maybe... ?
Measurments with original values :
R5 (4.7KΩ) = 20.50v after R5 (19.38v Orig-mod)
R13 (27KΩ) = 58.40v polar (57v Orig-mod)
Fet D = 15.78v (14.35v Orig-mod)
Hi, I'm on a break now.
Let me understand exactly:
with R13 27k stock (no VR), R5 4.7k stock (no VR) and 9.1v Zenner in series with D1 and D2, what voltages do you have, with the Presonus interface?
For both microphones
