I've linkwitz modded a couple transsound caps - namely the ts-60 caps.
Though the mods do the trick with raising the spl, of course, the self noise doesn't diminish any.
So -
Today, I opened up a ts-60 capsule, pulled out the tiny circuit board and bypassed the internal (eensy weensy) onboard fet altogether (accomplished with a razor blade and drop of solder). I put the capsule back together as best as possible and attached an external fet and 1G resistor.
I attached - this mess (which is what it kinda became) - to a circuit (the scott Helmke "alice" circuit) and in addition to a lot of hum and hiss, got sound. The mic does work, however output is very low.
What I'm wondering is -- has anybody attempted this, and if so - what was their outcome?
I have no question in my mind that I compromised this capsule sonically. That's not my problem. I'm wondering if I am able to seal it up nicely, would externalizing the FET help?
For this experiment I used an nt4416a (cause it's what I've used for other mic projects).
Any suggestions, anecdotes, etc.?
[/img]
So -
[/img]
