Severed family divorce party DIY extravenganza!
Rocinante
Minnehopeless
Well as you know ladies and gents; Life is s***.
You crawl out of the cradle through a war zone of hostile territory into a shallow grave, your body  full of blue junk to keep you looking like a f***ing mannequin.
We seperated.  The studio is half the size. Which means I have to unload a lot of stuff.  Which means you are gonna get some stuff for pretty cheap.  The whole thing is just sad.  I'd venture to say that  half my bands songs were about her.  The boy is taking it hard too. That's the worst part.
So lets have a severed family divorce party!!!!!
Up first is some is some non-DIY
ART VLA II.  -  Shoot me an offer but she has rack ear fatigue.  She works perfectly though and I've owned her for over 10 years.
https://postimage.io/
You see that piece of above it.  That's an 1176 type fet compressor using a circuit made by Gustav (PCB Grinder) which he called a Phat Phet. It works like an 1176 and sounds like an 1176.  It is IC in and transformer out.  It says Omnia Audio on it and if i die will be worth millions.  JK.
-Make an offer.
Up Next is a Five Fish x-12 in a 1u rack.  It is a great API style mic preamp.  The front panel was done by me but I think i have a front panel done by Five Fish which is made for a dual channel.  It is similar to CAPI.  Cinemag input and EA output transformers.  I have recorded tons of guitars and vox with it and it has always come through.  It is a bad ass mic preamp.
-$300
You see that awesome looking 4 channel mic preamp below the Five Fish in the first pic?
That's an m-3124.  Mitsos from GDIY (Analog Allstars) made some API 312 circuits.  That is a 4 channel version and so the M-3124. I used this on entire albums for drums and vox and electric guitars.  The pic below doesn't show the other channels stuffed but they are. Two channels are gar 2520 and two are
Gar 1731. Two channels have EA output transformers and two have Cinemag.
All use EA2622 input transformers.
-$1000
Harrison Ford Filters -SOLD
SOLD - G7 Pcb and se electronics tube mic -SOLD
A box full of resistors and caps - SOLD
DBX EQ -$30
I have no idea if it works.  Probably.
https://postimage.io/app.php
Neumann w492 dual channel eq -
This is an awesome EQ.  I hate to see it go but it must.  I hate to see lots of things go but they must.
-$600 is more than fair.  It's a f**king steal.  You would be robbing me.  I could add some features for more cash so inquire.  It's housed in a used case but durable. Also it says Omnia Audio which again; millions when I die.
Everything in the above pic is for sale.
I also offer a lifetime warranty.  So you buy one of my builds and it breaks you send it to me and i will fix it.  I doubt that will happen but will say it.
an unfinished D-AOC. I don't know. The 470 ohm 2 watt resistor right at the front of the circuit is nearly melting. I have a 25 watt 500 ohm resistor in there and she gets hot. Seems like the power transformer (which I got from Don Audio and seems fine but is showing 270v when it was supposed to be 250v) but I can't spend anymore time trying to figure it out.  If I had a spare 220v 9v transformer laying around I would probably switch them and it would probably start working.
I also have a desk full of unfinished projects. Hitherto it was my only DIY failure and a big one as this is an awesome compressor that I already built one of but sold to a friend cause I am stupid.
This has two vactorals per channel as I did the Kubi mod.  It also uses a switchable slope selector that was made by Majestic12 allowing you to use different led's which light up on the front panel.  I usually do my own front panels but this time I had Frank Rollen do the front plate as I wanted to do the Manley type plate over front panel look and he is the best. Looks slick anyways.
Its stuffed full of edcor xfmrs and the pcb is stuffed with nice caps and resistors. Comes with a ton of tubes too.
SOLD-Fully stuffed Forsell opto comp pcb, with vactorals with case and fpd files. -SOLD
I'll post more stuff and pics soon.
Howdy duder. Having bought from you before I'll send a bump here and offer condolences. Looks like some good stuff. Good seller folks! Sorry about the **** storm.
Sorry to hear your down and troubled.
My best wishes for you and for getting the stuff cleared out.
Sorry to hear about your troubles, I wish you strenght to go on.
Would you mind to share the desing on the M-3124 front panel? Its beautiful! Did you do it on Front Panel Express?
Kindest regards, Anders
Thanks for the kind words gents.
I keep hearing 'you'll be alright.' I believe that even though it really sucks right now.
Yes it was done in FPD and i will gladly share any design. It fits mitsos boards perfectly.
Also the d-aoc is using two vactorals as per kubi and has an led rotary board for the compression slope.
You'll be alright!
Gustav
takes a while for wounds to heal, but slowly it'll pick up speed
exercise is a great way to neutralize moods though, if even only a meditative walk
problems don't go away , they just don't seem quite so big
fortunately there were no kids , that complicates things
How much for the caps ?
Updated stuff and I'm getting some really supportive messages and comments and I truly appreciate it guys.
Dylan
