Kid Squid
Hiya Chaps,
Been busy as a busy thing, the last few weeks doing mad 16hr nights,
nice to see ya all :thumb:
Anyway,
one of my work mates, asked me to have a look at his Seymour Duncan Convertable 60W combo, after he re-capped / re-tubed, after having it given to him.
As soon as it's switched on, it hums like mad, so I looked at the power rails, and one of the rectifier diodes, was not rectifying. So, changed the diodes, and I'm still getting , what looks to be half wave rectification, coming straight off the diode junction.
Found the schematic online this afternoon, http://www.diyguitarist.com/GuitarAmps/Convert60.htm
on the bottom of the page it is.
here'sa pic of the scope, showing what i mean.
B+ after diode rectifiers, before C8,9 R55,
Her'es a pic of the Phase splitter anode volts
pics of the Anode Volts on O/P EL34's
and the 'funkiest' one
This is across the output (8 ohm 50w)resistor !! (0.7 - 0.83 VAC)
Surely it's gotta be the power supply, injecting that much ripple onto the plates ??
*Just had a little check about*
I disconnected + of C8, R61, and R55, and the B+ waveform is still the same. Surely, its the rectifier stage ??
Whats the deal with the four Diodes, on a CT secondary, and with them resistors R65,66,67,68 'shorting the diodes out?
do they pass current, until, the forward bias is exceeded on the two diodes per leg ?, 'pre-charging' C7 /C8 ??, like a soft start type of thing ?
or am i talking bollocks :wink:
edit.
* I was talking bollocks !, its a parallel RC filter - a way of getting big capacitance / votage for the buck, the two resistors are equalising voltages for the two 250V caps in series.*
checked over my mates soldering, - all ok, but the only thing different i've noticed, is that the replacement C9,10,11 are 20uF, not 22uF, but the actual measurements are ranging from about 26 - 29uF....
also, CR12, and the jumpers - jmp1,2 are not fitted, and they look like they never have been. ( something to do with the unused doubler circuit)
...........I have been working a LOT of nightshifts tho....... :wink:
Any ideas are apreciated fully !
Steve :thumb:
Anyway,
edit.
Steve :thumb:
