poppaflavor
Active member
Aaargh. I know this is such a dumb question. Are active EQs and compressors (solid state, presumably op amp, not tube) supposed to pass the same signal when the are powered off as when they are powered on?
It's happened to me twice. Once with a used XTA graphic EQ bought from Sam Ash a few weeks ago, and now again with a brand new EQ/compressor from a reputable company.
The devices pass full signal when powered off.
I'll describe the new EQ/comp here since I have that in hand and am seriously fretting about the situation. I reached out to tech support at the EQ company but haven't heard back yet.
So here goes... I tried the new EQ with a two track mix, but no matter what I dialed I got no effect on the audio. Input, output gain maxed out or set to minimum? No effect. HPF, LPF at severe settings? No effect. Compressing on EQ bands? No effect. Finally out of frustration I turned it off and it was still playing the same level and sound as when on(!). Which frankly freaked me out.
So I used REW to assess signals through it.
When the EQ was turned off I got the same exact REW frequency response through the new EQ as I did through a loopback test (FR 18i8 DAC -> ADC).
Also, the same exact frequency response and level when the EQ is on whether bypassed, EQ in but set flat, any combination of dial settings, etc. It just passes the same signal no matter what.
I recorded the two track through the EQ powered on and then again with it powered off. Played them at the same time and flipped the phase on one track. They nulled quote a bit, down to about -35 dBfs residual signal.
So, obviously the unit is jacked up because it doesn't do anything. But also, should an active sold state EQ/Comp pass signal when powered off? If not, what would allow this? A short circuit?
