Shure SR 107 documents question...
iomegaman
GDIY Supporter
Tucson, Az
So I posted the tech documents in the appropriate thread but both I and OneRoomStudio have some questions about the documentation:
OneRoom asked:
"That output transformer is strange. The block diagram shows that the “line output” tap is -2dB (so something close to a 1:1 or 1.25:1 turns ratio), but it says the “mic output” is -52dB!
-52dB is a huge ratio…something like 400:1. If we assume that the primary impedance is around 10K (it really shouldn’t be any higher if it has a something near a 1:1 tap for line out), the output impedance of the mic winding would be something like 0.0625ohms. That can’t be right, can it?"
I measured the actual transformers and posted this:
Ok just measure the Transformer here's the actual data:
Primary (blue/red on schematic) = 66.4 Ohms
Secondary (white/green on schematic) = 66.4 Ohms
Secondary (brown/yellow) = .4 Ohms
For the "Mic line" output feature (brown/yellow):
Using .078 to determine turns a=ratio that makes it a 12.884 :1 step down for the mic...
If you read the manual it has a setting to run it out kind of like an inline EQ for consoles that use a "Link" jack it outputs a really low mic level there.
To which he replied:
Huh. 12.884:1 is only around -22dB, not -52dB. I wonder why they marked it that way.
and I followed with this:
Primary= 27 Ohms
Secondary = @ 600 ohms...I double checked its wired that way...
Green/yellow to XLR= 27 Ohms....black and white to amplifier board = 597 Ohms...1:4.7 step up...
Possible error in the schematic data?
Is it just an error or did we miss something?
  • sr107.pdf
    4 MB
  • shure_sr-107_schematic.pdf
    3.9 MB
