siemens w295 recap >> 3/4v electrolytic capacitor ?
alexgg
hi
I am attempting to recap a siemens w295 eq
I removed one electrolytic that appeared suspect + found it to be marked 250 uf , 3/4v ??
does that sound likely , 3/4v electrolytic ?
I cant find any for sale today, is there an alternative?
it is C18 on the schematic as per kubarth
3/4 makes no sense, but you can use any higher voltage cap in it's place.  6v for example.  Or to be *really* safe, use a 35v cap which is higher than the power supply voltage.
*edit*: Just looked at the W295 schematic (not W295b) and it shows 11.5v at C18, so use a 25v cap and forget about it.
thanks a lot mjrippe
so 25v or 16v also ok then I guess ?
I looked at uk stock and I cannot find anywhere selling 250 uf , 25v in Europe
only usa (high delivery charge)
would a 270uf , 16v or 25v be ok ?
( these also all seem to be radial , not axial as per 250 uf)
oddly these might be easier to fit if really tiny
I have also attached some photos so you can see the original markings and maybe make sense of them
thanks
alex
    415.8 KB
thanks Michael
so you also think 25v or 35v even actually more appropriate.
tbh it is in a very tight space + smaller would be easier to fit.
maybe 10 or 16v is ok ?
my main problem now is low availability of 250 uf in Europe
270uf available but all seem to be radial which might be easier to fit.
so you think a 270uf,
16v slightly smaller than 25v
would be an ok replacement ?
Yes, higher value and higher voltage are always OK, within reason.  Old caps were often +30%/-20% rating.  A 2000uf 300v cap would obviously be too much and way too big!
