Sifam La2a Meter Nut Size
Clbraddock
Columbia, MO
Does anyone know what size nuts fit the back of a Sifam LA2A meter? I received one that was missing all of the nuts.
Also, is it okay to use stainless steel nuts in the brass posts or do I need to use brass nuts like what it is supposed to come with? Is there a galvanic danger using stainless steel? I have a lot of miscellaneous stainless steel nuts on hand but don’t really have many brass ones.
Thank you that's very generous! Will send a message.
Separately, I am pretty sure these a M2.5 from what I have been able to research. In case anyone else has the same problem in the future.
