Simple DiodeBridge Compressor
Very proud ... It sounds really cool... Tests went fine... Each kind of track i send to It sounds great... Now Gr Meter It s ok ... I can draw a shaped PCB for that Gr driver to fit into
i ll upload 2 bounces of a drum stem ... Fast and moderate release...now I can t from my old mobile
Best
    2.1 MB
here the samples
i only forgot to bounce the original flat drum... but you feel the difference between settings
the stem it s only balanced in level no processing on tracks
25ms Release it s max Ratio and Threshold - EDIT: 22ms , i typed it wrong
400ms Release at moderate setting
attack it s fixed at 3ms
thanks for your attention
best
  • dsb 48 25ms.wav.zip
    15 MB
  • dsb 48 400ms.wav.zip
    15.1 MB
i m going to implement a relay Bypass into the 500 proto
for this occasion i m thinking to add also the Meter driver in this new board
the unit is developped this way:
-lower pcb is ch1 with signal and its own detector, the latter linked to ch2 detector
-upper pcb, ch2 , also contains the entire sidechain
so my question is:
where is better to take the psu for the bypass/meter board?
was thinking to use ch1 cause it has less components...
or is it better to redraw it and put relay-bypass on each channel and make a separate pcb for sidechain and meter?
doesn t matter which channel will supply the new PCB?
hope I was able to explain myself
thanks for your attention and support
best
richi
Had time to get measurment
zip file it s .ods format
Slope pdf used REW with Tukey 0.25 tone burst
Thr pot at 12 o'clock, -20
when setting Thr to max, -28 , Ratio from 8:1 goes over 10.xx :1
best
richi
  • Slope.pdf
    415.5 KB
  • DSB548-SLOPE.zip
    24.6 KB
    54.2 KB
