R48 in the signal path... Is 3k3
The side-chain i divided into 2 boards
The first one for opa buffer, hpf and detector, the 2one the controls....
This way you can add a second buffered detector for stereo version, for different tracking mode
The switch sw1 in the side chain can be not wired if you build a stereo unit with one control board
Sw2 and 3 are a double pole switch….. it s autorelease, here I did an error!
Forgot to wire sw3 to ground when not engaged in the pcb , so just wire from switch to ground since the footprint in the pcb is not wired ( the squared one ), and the other 2 have to be reverse wired
For calibration I did this:
Sidechain trim totally Cw
Set meter trim to have needle to zero
Now turn ccw the SC trim till needle goes down... Now set it again to zero rotating cw the same trim
Measuring Cv out i get 0.5mV
hope everythign is fine
Next step i ll try 8 diode as Heikki did in his unit
Best
Richi
