simple tube mic preamp
ok now i see the confusion of it
i will try to draw it again.
that shunt isn't quite right.
really it has to be a voltage divider but i draw it complete wrong (i think it was late that evening).
i don't say that the mila isn't good enough but you know copying is one thing and it is easy to do but to really make it your own is another. and i like that.
my tought was to have an output stage that is good lineair with some feedback and has always the same gain.
you then have a volume controle (the 100k pot that is completely drawn wrong here. normally the midpoint had to be at the input of the output stage)
the input stage consisting of 2 triode halve's does gain and that is controled by a switch.
the purpose is to chose the coloring (not to much but a little maybe)added by the tubes by having more gain or less gain. and then adjust the volume pot that passes the signal to the output stage.
it was just a tought and if it aint clear then tommorow i will have a good schematic.
and if it aint a good idea then i will do something different.
srry for the confusion
and thx for the reply.
