[quote author="JohnRoberts"]
There has been a great deal of study and knowledge documented about human perception. I took advantage of some of the time dependent perception characteristics while designing tape noise reductions and dynamics processors ('70s-'80s) to help conceal the gain manipulations.
[/quote]
Is it possible to find some of them?
PS: In a perhaps not surprising data point, customers preferred an older generation noise reduction wrapped around the analog delay chips that exhibited significant amounts of low order harmonic distortion. Since the customer is always right and it was after all an effect intended to alter the sound, adding distortion in this case was perfectly consistent with the products design goal (to make stuff sound good). IMO The design goal of a reference playback system is to reveal what's there, not change it. YMMV
I agree with you about "reveal ... not change". The question is, what "not change". It is impossible "not change" at all, something always will be changed. The question is, what. People tend to pay attentions to some "side effects" of "less changed" sound such as high level of lower order additional harmonics, while main reasons why it seems to be "not changed" slips through fingers...
Like all strings are aligned perfectly horisontally, but the piano still sounds out of tune... :roll:
[quote author="Kit"]
Speaking of audio we have to measure them against subjective perceived levels
You said it yourself......"subjective" is the keyword here.
My ears might favour a different opamp than yours.
Data and specs is the only common language we got on this matter.[/quote]
Sure. My point was, distortions' change means more than some absolute level of them. Everything flows, everything changes. Look at a snake in a cage if it does not move. You don't see it, I guarrantee, if it is still. But if it moves far from you, far from your direct sight, you will immediately turn your head, blood pressure will rise up a bit, adrenaline level will go up immediately. Similatry, switch on a light bulb in your bedroom in the middle of the night, to discover how bright the light is, despite it seems to be very dim during the day when the sun shines. Dynamics, this is what is more significant. Everything change, and we are trained to spot
changes.
However, it is possible to measure sensitivity of human eyes to different light frequencies, also it is possible to measure gradations of light that seem to be different, depending on the background brightness. The same with sound... Human perceptions were trained a long time, generation to generation, no matter if to believe Darvin or Church clerics, anyway all our perceptions are best suited to live in the real world, where brightness, loudness, temperature, change in certain levels, and some levels are better recognizible, especially when they change.
Back in 30'th Fletcher and Munson experimented with loudness' perceptions and found that different objective measured levels of sound of different frequencies seems to be equal in loudness, and such loudness - frequency dependency curves depend on sound pressure, and such curves correllate well from listener to listener. I.e. subjective perception curves may be objectively measured!
You may experiment for yourself, and probably your perceptions are similar to perceptions of other people, no matter what kind of operational amplifiers do you prefer.
http://www.phys.unsw.edu.au/jw/hearing.html
