bcarso
[quote author="JohnRoberts"][quote author="ruffrecords"]
This is completely wrong. Global feedback does not compromise bandwidth.
Ian[/quote]
No, but the internal compensation required for stability with negative feedback does indeed.
I'm no student of scope schematics so the following is mostly WAG. They probably use less overall NFB and apply it locally rather than globally to minimize this constraint. They may also favor phase and amplitude response preferentially over extreme linearity as we are not going to eyeball nonlinearities more than say 30-40 dB down. or not...YMMV
JR[/quote]
Thank you John.
Let me be a bit more precise. Scope amps are an example of wideband lowpass circuits which attempt to get acceptable transient response, usually aiming for Thomson filter shape, i.e., low overshoot and fast settling, with the maximum gain bandwidth from the active devices that are available at a given time.
Negative feedback in the sense of Black's invention is typically viewed as a method of reducing gain in exchange for reduction of distortion and improvement in gain stability. And in order to assure stablity against oscillation the open loop response in terms of gain and phase has to meet certain criteria, the details of which are well-represented in books and courses. Additional considerations must be met as well in terms of the feedback network itself, and the overall resultant topology is what is studied to determine the transient behavior.
If I am building a scope amp and want it to have significant gain and reasonable stability, I will more likely get there by cascading gain blocks with relatively simple gain paths, and not chaining a bunch of stuff together and applying negative feedback around the lot of it. And that's what I was alluding to when Lazy mentioned his scope differential amplifier as being something that might approximate an opamp. It is not likely to do so, and the accumulation of phase shifts if it follows typical scope amp practice will not lend it to use as an opamp per se---that is, it will not tolerate the application of global feedback of the typical sort.
Ian[/quote]
JR[/quote]
Thank you John.
