On Power amps, I've seen sharing the B+ directly between channels, but what about on Single ended amps?
This preamp has a mono schematic and I housed 2 of them in the same chassis to run in stereo off the same power supply. They're single ended and I get oscillation/interference between the channels. The problem is in channel 2 but I get junk in channel 1. Disconnect ch 2's B+ and the problem goes away in both channels.
The B+ ends with a cap to ground (last PSU Cap) between the channels, so I figured any junk would go to ground.
This is troubleshooting, but the real question is how to share a power supply between 2 SET amps, so I posted it here in the drawing board forum.
