oragall said:
TNX... i try with a more close value of 800pf and change the 150pf to 47pf or other value more lower than 150pf.
Have any formule to determine the phase error?
and the basspas how db per octave is? eight???
Cutoff frequency where amplitude has dropped by -3dB is 1/(2*PI()*R*C), giving 70735.5Hz for 15k and 150pF.
Phase response for this LPF is ARCTAN(testfrequency/cutofffrequency)*180/PI(), giving 15.79° for cutoff 70735.5Hz tested at 20kHz.
At testfrequency 20kHz this has an amplitude response of LOG10(1/(Root(1+Power(testfrequency/cutofffrequency))))*20, giving -0.334dB.
With 47pF this -3dB cutoff goes up to 225kHz, giving response @ 20kHz of 5.06° and amplitude drop -0.034dB.
A NE5534 should work stable up to this range.
Your 2000uF cap in the shunt arm would have a HPF -3dB cutoff @ 1/(2*PI()*R*C), giving 0.53Hz for 150R (=worst case max.gain setting).
Phase response for this HPF is -ARCTAN(cutofffrequency/testfrequency)*180/PI(), giving -1.52° for cutoff 0.53Hz tested at 20Hz.
At testfrequency 20Hz this has an amplitude response of LOG10(1/(Root(1+Power(cutofffrequency/testfrequency))))*20, giving -0.003dB.
A 470uF or 680uF cap is probably big enough for your application. YMMV.
