Svart
Ok, so we all say and *know* that a single opamp can't possibly make a difference in sound right? I've always been skeptical of this but I think for the most part it's true until you get into certain situations..
here's my story..
so I was working on some new material in the studio and needed to use a number of channels in my console. I used 4 channels for cymbals because i needed to mute and change EQ( i only have mute automation.. :sad: ) but when i record all the tracks I do them dry, without compression, without EQ and so on. When listening back I noticed something strange.. two of the tracks sounded normal and good as usual.. the other two sounded lifeless and limited in headroom. oddly enough I have modified both of these channels in the past with high(er) quality IC opamps, removing coupling caps out of the audio path, upgrading supply decoupling and so on. FYI, the channels have 1% metal films throughout also.
Of course I couldn't stand to have such a noticeable difference between tracks of the same material, so i removed a blade of the *good* channel and a blade of the *bad* panel.
I traced everything and tested parts to find no problems with the actual parts themselves but I did find ONE difference between the channels...
on the *bad* channels, I had somehow left a TL082 in the audio path, It was either the booze or the sleep dep but it happened... the *good* channels have an OPA2604 in place. everything else was the same. I removed the TL082s and put sockets and OPA2604s in their places. I returned the channels back to the console and juiced it back up.
I now hear NO difference between the channels.
Now, I think if you have a ton of TL082s in your audio path and replace a few with something better, you won't hear much difference.. but reverse the situation and leave a few TL082s in a console of high(er) quality parts and you will bottleneck your audio. this is what i believe to have happened to my channels. they just sounded strange and choked until the odd part was replaced.
any thoughts or opinions?
am i nuts?
should i get drunk and forget about it?
should i get drunk and forget about work?
should i just get drunk?
:green:
here's my story..
am i nuts?
:green:
