0dbfs
I have a couple doner mic's that I would like to turn into something and learn from.
My goal is to ascertain what I can about the existing capsules, and build an amplifier circuit around the existing capsule in the existing body that works.
The mic's are front address condensers and the existing circuit has been modified in a way that makes the mic's un-useable for me at this point in time.
I plan to research the various fet circuits and build in a simple 48V fet circuit for these mic's. I really want to keep the initial cost down and learn a bit and may plan for some higher grade trafo's down the line. I have some different trafo's around that I might be able to use for these.
I plan to keep the capsules, use the bodies, and replace the amplifier.
The mic's in question (un-named for now) use a "stretch-rubber" type of capsule mount system which appears to be common for several of the mic's they sell. They also use a very thick PCB instead of internal support rails which attaches to the capsule mount system. The body tube slides over the PCB and screws into the XLR-base section.
I don't have any reason to believe that the existing capsules are anything "special" or particularly uncommon.
I am wondering what test methods I might be able to use to determine the ideal operating conditions of the capsules (I can't find any specific tech information about these capsules). ie; optimal or acceptable voltages, response characteristics, etc. Are condenser capsules generally "ok" within a certain range of operational parameters. ie; loading impedances, polarization voltages, etc..
Thanks in advance,
jonathan
Thanks in advance,
jonathan
