strangeandbouncy
Dear PRR,
Thank you so much for your posting. Just to clarify a few things . . . I use this La4a daily as vocal compressor. Simple, I hardly ever adjust it. Easy set-up for both recording and mix. It is just "plug n' play". Many different artists visit our studio, and many different so-called "engineers". My particular combination of Neumann U48, Consant-impedance attenuator, Helios Mic-pre and La4a is about as universal as it gets. I can set it for visiting peeps the night before, and spend my day off at home! One size fits all. I can recreate every single vocalsession everytime, and with an awesome sound(for most vocalists, anyway). My Protools inputs are 882's giving -14dB equals 0dB ref +4db - ie 0dB - on my vu's!- please excuse me if i have transgressed the correct nomenclature, but i think you know what I meanses! I like to record as if going to a 2" from habit, so naturally I don't like to see the vocal going over @0dB on my monitor vu's on the SSL. Helioses are 0dB, NOT +4dB out., hence, I like to see not much more than -4dB on my vu's. this gives me @-10dB peaks in my Logic/ProTools, @ 4dB lower than I would normally leave with higher rated mic-pres. I prefer to leave @ 6dB in hand normally to allow for "divas" and screamers. I totally accept that exceeding 12v input will result in clipping( of the mic pre if nothing else,) but this must have been the case before substituting a transformer, since mic pre gain is the same, and there are no ic's(with their much reduced headroom over transformer) in the input anymore! Sowter is rated at +34dB . . . . My comparisons are at the same (lowish) levels as before, but this represents the(well, My!) real world of Digital.
my so called "mythical Threshold" IS what Jung was talking about, ie 0.5v/us for each Volt out! - still doesn't explain why API stuff sounds amazing even at rediculous output(will handle +30dB!) I know that actually the electronics are handling 6dB lower than that due to step-up 2503 transformer, but stll, shouldn't they require a slew-rate MUCH greater than 3v/us? I guess there is other black magic at play here! Or perhaps I just like the particular slew-rate distortion of the 2520, and not that of the 4136?
most interested to note that you don't think I'll find so much improvement in the output stage. This would make my life much easier! :green:
KInd regards,
ANdyP :green:
KInd regards,
ANdyP :green:
